indirect or direct electric resistance
Hilly
Hilly Member Posts: 429
I need to replace an oil boiler w/ tankless coil. The customer is very set on going with an electric wall hung boiler for the setup, likely a Slant/Fin. Is an indirect more efficient than an electric hot water tank? His new boiler will be off electricity anyway so in short the questions is does he add another breaker to the panel and put in electric HWT or use an electric indirect?
  • SWEI
    SWEI Member Posts: 7,342
    If they have the service capacity
    I'd install a tankless electric water hearer or three.  Depending on the house layout and size, two or three smaller units can frequently work better than one big one.  You can also squeeze them into a smaller (electrically speaking ) service.  They will occupy 2-4 breaker spaces each (six for the big ones.)  I've had good luck with Stiebel Eltron (and the company seems to be here for the long run, unlike a few others we've seen.)
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,096
    Would a heat pump...
    ... work for the DHW load?
    Yours,  Larry
