New system help
Brockway
Member Posts: 1
I'm installing a new rad floor staple up system in my son's 1500 sq ft single story house. We will be using 1/2 pex with 2 lines in each joist cavity. I have used a watts mixing valve with success in other systems I've installed,but I'm wondering if there may be a more efficient piping scheme. He is on a minimal budget so mixing blocks are out of the question. We will have 3 zones, 2BR zones and a LR/ KIt zone. We have 007 pumps (used but in good cond) available to use and are hooking to a Weil Mclaine CG-4. . The house was built in the 40's with little insulation. As he can afford to tear out the plaster he insulates the outside walls, and there is 9" of glass n the ceiling. I'm open to thoughts opinions and drawings
spend a few bucks more
and get a Taco iSeries-R mixing valve. The increase in comfort and efficiency is significant, and it also takes care of boiler return water protection.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
