Taco 007?
ChadZeilenga
Member Posts: 12
I have a steam system that was converted to a 2 pipe sometime in the past. I have a cast iron boiler that is ~20 years old. Last winter I replaced the old Honeywell L8148E with a Beckett Aquasmart controller. I believe the B&G Series 100 is original to the boiler, and I'd like to replace it. I believe the Taco 007 is a suitable replacement and shouldn't pose any issues with my Aquasmart. Does anyone have any experience with this? My home is ~2000 sq. ft, 2 story and a single zone.
Is it working OK now?
What kind of ∆T are you seeing on the system? 007 curve is different and the Series 100 is completely rebuildable.0 -
Cold start
The boiler is set up as a cold-start boiler with the "learn" function active on the Aquasmart so it determines its max temp. I believe it was around 140F though.0 -
By ∆T
I mean difference between supply and return water temps when firing on a cold day (ideally a design day.) Translation: Is the Series 100 moving more water than you need?0 -
Delta T
Sorry, I don't have that info. Should have gotten that before the winter ended. I would have to wait until JAN to get true numbers. I believe the pump is original to the boiler installation. The whole system is a high mass with all cast iron rads. When I installed the Aquasmart I started to get kettling inside the boiler so I thought the pump might be bad and was going to swap before the weather got too cold.0
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
