Wanted - Gas burner gun for 125k input
Matt_Connolly
Member Posts: 14
Looking to switch to gas from oil, boiler is a Trianco, 125k range will work plus or minus 20k. What do you have?
<a href="mailto:Matt.connolly3@gmail.com">Matt.connolly3@gmail.com</a>
610-392-7020
Thanks!
Also - I'm a full time auto mechanic, so if your work truck needs brakes or other repair I'll gladly trade.
Matt
610-392-7020
Thanks!
Matt
Gas
Are you planning to install this yourself? Do you have a combustion analyzer? How do you plan to alter to the venting?0 -
I wasn't aware
Trianco marketed oil boilers in this country. What model is yours?All Steamed Up, Inc.
Consulting0 -
Yes, I am, and Yes, they do.
I have access to an analyzer and I have seen other boilers identical to mine on other jobs. But really all I want is a gas fired burner gun! I'll buy a new one if needed, but I'd rather buy one from a guy who pulled one from a job or has an extra one.0 -
Gas
Where are you located? We often have spare burners around the shop.0 -
Near Allentown, PA
Bethlehem, in fact. An hour north of Philly, a bit more than that west of NYC. Let me know what you have.
Matt0 -
Model is a HC 145
And the flange is the standard 3" size. Looking for a gun to fit in there for the conversion. It's getting cold and I can't go back to oil - the tank is too old and can't be changed since the house has been modified since the installation and there's no way to get the old tank out or get a new one in.0
- 15.8K Strictly Steam
