Condensate meter
gcp13
Member Posts: 122
district steam
5 psi is still a bit high for radiator/ main vents/traps to handle. can it be dialed down?--NBC0 -
Lower presure
Yup,going back when heat is on to test return Lines
& try to cut down the presure it may need that presure
To push condensate back lots of back pitched lines0 -
steam valve
The Old Spence amd hoffman press. reducing valves required a set horizontal pipe length coming off the outlet piping as well as the pilot piping, If the piping run was to short the valve may hunt and have a hard time maintaining lower outlet pressures.There was an error rendering this rich post.
Lower presure
Thanks good info. Not sure how much we'll end up
Doing. The piping is a mess but they have no
Complaints about the heat0
- 50 Industry Classes
