Micro channel coil
The micro channel cond coil is leaking, two passes up from bottom,  it is in the middle of the "tubing". Its in a Coleman and the warranty/handling is superb thru Johnstone.
  • Techman
    Techman Member Posts: 2,143
    So much for good service
    from Johnstone Supply! The in warranty cond coil has still not arrived. Go figure! The customer opted for a new cond unit from MCN Distributors several weeks ago. Will that deterorated cond coil fit where the sun doesn't shine?
  • John Mills_5
    John Mills_5 Member Posts: 952
    wow
    Will it fit? Give it a try and let us know - relieve some stress!
