Daikin Air Conditioner catalog 2007
Hi All:
Does anyone have a Daikin Air Conditioner catalog published in 2007 or thereabouts? The question involves a patent. For example, I think that the following unit was sold in 2007: Daikin Split System, RX15FVJU and FTXS15HVJU. I obtained this information from a thread published in 2007.
Thanks for the help.
  • alotlikeearl
    alotlikeearl Member Posts: 68
    Not Sure
    I have one but I'm not sure if it is from 07 or 09.  It is not dated but has the following code on the back (GPUSE09-07B).  Both models you mention are in it.
                      Jerry
  • J_Arthur
    J_Arthur Member Posts: 4
    Hi Jerry:
    Thanks for the reply. Could I borrow this catalog and make a copy? I could send you a Fedex envelope. After copying, I would send it back to you. Or, this may be asking too much, if you could make a copy, I could reimburse you.
    Thanks for the help
    Art Wagner
    1649 Fairorchard Ave., San Jose, CA, 95125, wagneretal@sbcglobal.net, (408) 206-3049
  • J_Arthur
    Jerry:
    Thanks for the catalog number. I found a copy on the web. You can ignore the discussion about sending a copy. From the document I downloaded, the year of creation was 2009. That's good infor.
    Thanks again.
    Art
