B F Sturtevant fan coil capacity?
WALLEYEKILLER
Member Posts: 1
Can anyone help? My customer has a very old system and part has been removed. He is replacing a steam boiler and is figuring the capacity. The coils are much like fin tube, have duct off the back, can't tell you if their is a blower or just outside air. There two 12"dx27wx34"h. Model 331616 10-design 175-size. They are no longer in business. Anyone out there have any ideas?
Worth a try
Have you tried going to sturtevantfan.com and using the contact link to see if they can help?
Good luck! Jerry0 -
If all else fails
use the capacity of the runout pipe to the coil. It might have been oversized but probably not by much.All Steamed Up, Inc.
Consulting0 -
If I have to
Guess 175000 btu.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
