B F Sturtevant fan coil capacity?
Can anyone help? My customer has a very old system and part has been removed. He is replacing a steam boiler and is figuring the capacity. The coils are much like fin tube, have duct off the back, can't tell you if their is a blower or just outside air. There two 12"dx27wx34"h. Model 331616 10-design 175-size. They are no longer in business. Anyone out there have any ideas?
  • alotlikeearl
    alotlikeearl Member Posts: 68
    Worth a try
    Have you tried going to   sturtevantfan.com  and using the contact link to see if they can help?
                       Good luck!   Jerry
    Steamhead Member Posts: 18,433
    If all else fails
    use the capacity of the runout pipe to the coil. It might have been oversized but probably not by much.
    Consulting
  • unclejohn
    unclejohn Member Posts: 1,833
    If I have to
    Guess 175000 btu.
