Leak seal
Paul S_3
Member Posts: 1,289
how do you guys feel about those refrigerant leak sealers....do they work/do they harm system?.....thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
sealers
Had a bad exp. used on a low temp Kramer hot gas defrost R 404 system , ended up with restrictions in systemThere was an error rendering this rich post.
so
What do you think is the best way to approach trouble jobs with leaks Paul SASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
leaks
One way is to press test with nitrogen, check with liquid leak det. solution. Another way is to use a good electronic leak detector while unit still has a refig charge or add nitrogen with a refrig. tracer. There are dyes you can put into systems, I found they are messy and hard to get out of your guages,There was an error rendering this rich post.
Leak Detection
Go with RJ; nitro and tracer refrigerant. Only two things belong inside your system, period: refrigerant and oil.0 -
I tried
Both Superseal, the one with the one time use hose and the other one that you can reuse a hose that is sold seperatly. Had a lot of trouble with superseal. Could not get it out of the can and stopped using it. So far with the other [sorry I can't remember the brand but in the DC area I've only seen the two ] I have been back to add freon on one. I'm not inclined to use either anymore.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
