Backwashing domestic tankless coil
HydroNiCK
Member Posts: 186
in Oil Heating
Hello everyone and Hi Ken Resnick,
I was recently bonding with my parents boiler and noticed there is a loop installed to backwash the coil. How do I go about doing this? The coil is 20 years old and I'm still getting sufficient hot water from it. However, since i'm fascinated by heating and would like to practice my skills, and can't leave well enough alone... I am thinking about back washing it. Now, I know how to backwash the coil with cold water but How do I do it with chemical? I searched the wall so please forgive me if this topic already exists (I have a feeling it does) please link me to it or provide the proper key words I should search ( I tried "backwash coil"). Also, feel free to let me know that i'm an idiot for contemplating using chemical on a coil that still works well. However even if i don't use the chemical I still would like to know how to run it through. Could I tie in a tee with a ball valve and male adapter so i could then hook a hose and pump up to the coil? I would stick the suction end of the pump into the bucket of chemical. Hook a hose up to the boiler drain on the loop to drain the chemical coming out of the hot side into a bucket therefore recirculating the chemical through my pump back through the coil?
Thanks,
Nick
Thanks,
Nick
Bonding with a boiler
sounds a bit ephemeral to me, but you might try flushing coil' on http://www.heatinghelp.com/forum/search
Generally speaking, you recirculate treated water (almost always moderately acidic) through the piping or coil until it is free of deposits. There are subtleties to the process depending on pipe/coil material(s), the deposited materials, and local water conditions.0 -
Thanks
Thanks SWEI0 -
if it's not broken
don't fix it. You could wind up with a pin hole or two. If you have any doubts, or having issues with hot water, replace it. Years ago acid flushing was done regularly. A lot of coils plugged, leaked, potential health hazard, etc. I know of no one who would take that chance today0 -
coil flushing
many years ago, i acid washed / flushed many coils....success rate was about 30 %....i would not try today because of possible health issues if acid not fully flushed out.... replace the coil, or take to a radiator shop, & have them soak it in a cleaning tank for at least 4 to 6 hours....../ my $.05 opinion...0 -
I agree
With the others, if its not broke leave it alone, how water is fine, you want to do something flush it really good, but I wouldn't go running stuff through it and disturbing too much...
You could end up bonding with some pretty stubborn tankless bolts..0 -
being a steam guy
I steam clean the coils I deal with during the annual service.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
