Expansion Tank
Val_LI
Member Posts: 9
in Gas Heating
Plumber I'm thinking to hire says I don't need Expansion Tank for my DHW.
I'm planning to have Lochinvar Knight boiler with Lochinvar 80GAL indirect water heater. There is NO recirculation line for hot water.
Plumber states since there is no recirculation line, no expansion tank needed.
Is that true? Please help me understand.
Some codes
require them for all installations. From an engineering standpoint, anytime you have a check valve (or something that acts like one) between the incoming water supply and the water heater, you need one. PRVs act like check valves.0 -
North Shore or South Shore?
The north shore has higher water pressure which has presented a problem sometimes. I recommend the DHW expansion tank and some manufacturers require it for the warranty to be in effect. Just my two cents.0 -
To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
