Fluidmaster 400A
Boiler Talk
Member Posts: 143
in Plumbing
I recently replaced that 1" gasket under the Cap, but I'm sure the unit is older than 5 years. The instructions on the replacement gasket say I should replace the whole unit. Has anyone seen a catastrophic failure because it was just older than 5 years?
fluidmaster
5 years old, you are fine, I have seen many way older than that.0 -
fluidmaster
if fluidmaster products were any cheaper they would be paying you to use them. open up your pockbook & replace the whole thing. the labor is the same , get a grip.0 -
throw-away society
that is whet is encouraged. If the washer replacement works, go for it. They sell more complete units if they recommend replacing the whole valve. It means more $$$$0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
