Zone
Mpj
Mpj Member Posts: 109
I'm looking at boiler replacement job with a total house load of about 75,000 BTU's. I'm thinking about a mod-con with a buffer tank. The house has 6 existing zone and a 80 gallon indirect, the zones are kinda small and only doing a couple rooms each. They have a interior bathroom that has a radiant floor which is about 1,200 BTU's.
How would you guys pipe in this radiant zone? Mixing valve? I series valve? something else?
Thanks
  • Rich_49
    Rich_49 Member Posts: 2,785
    Is this
    bathroom it's own zone with a dedicated thermostat or an individual loop off of a manifold ?
    732-751-1560
    Rich McGrath 732-581-3833
  • Mpj
    Zone
    Yes, the bathroom is its own zone. It currently have a three way mixing valve off the boiler. It has a t87 thermostat controlling the circulator.
  • SWEI
    SWEI Member Posts: 7,348
    Total houe load
    Is that a calculated heat loss?  Why so many zones?  Might be an opportunity to simplify things...
  • Mpj
    load
    Yes, that is the total house load. He want to keep almost every room on its own zone.
