Silly question
tinnerjohn
Member Posts: 4
in Oil Heating
What is a "tiger loop". I've seen references to them here and in other forums, probably have seen them before or maybe even used / made them, but under a different name. Thanks John
It's a de-aereator
That hooks to to pump with two pipes while needing only a single line to the tank.
http://www.westwoodproducts.com/tigerloop_article.htm explains it pretty well.0
