Barrier X-5 underslab insulation
Simply Rad
Member Posts: 200
I have a contractor that has asked me to do some research on a underslab insulation called the Barrier X5. We have always in the past used 2' Blueboard underslab. He recently spoke another contractor/friend who told him his experiences with the Barrier. He likes the facts that it is not only a insulator but also a vapor barrier.
Is it truly an insulator of R 7.2 Blueboard is the proven product and I want to make sure we are doing the right.
What do you think?
What do you think?
Jeffrey Campbell
Barrier X5
is a very good product for beneath slab insulation . the R value is there and vapor barrier to boot . Easier to install than XPS boards , it won't break . All around the best value for my money anyway . Have used it for many years now and would not consider anything else . Best way to explain Barrier X5 is this , think about an 1 1/4 thick Dunkin Donuts coffee cup , still warm 30 minutes later when it's 35 outside .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Barrier X-5
Rich
Thanks for the input. It does seem like a better product on paper, but as we know paper and real world are very different. I think my biggest concern is when the wire mesh is layed down. There is a lot of potential to rip the top layer of vapor barrier. I know there is still the bottom layer, but to keep both intacted is a hard task. I saw on the sales brochure that the product when installed with a concrete slab has an R-7.2. Our new energy code is requiring an R-10. So this project may require 2 layers of the product. Maybe The Barrier Co will acknowledge the new energy code and start producing a R-10 product. Thanks again
Jeffrey CampbellJeffrey Campbell0 -
Barrier X-5
Rich
R-rating
Check the R value for just the material. The brochure from their website states that Barrier X-5 (material only) has an R value of 5.3. The R value of 7.5 is using the X-5 material plus the R value of the concrete. I happen to like this product and used in in the radiant slab in the basement of the house I built a couple of years ago. Because the R value is insufficient for the Barrier X-5 alone I used 2 inches of blueboard on top to give me a total R value of 15.3. This also protected the X-5 material when I was installing the reinforcing mesh and radiant tubing.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
