Carrier Blower Issue
JamieP
JamieP Member Posts: 27
I have a Carrier 58VLR105---11112 low boy oil fired furnace with a variable speed blower.
The green LED light on G is illuminated but the blower is not running.
How do I determine if it is a bad blower, harness, or board.
There is 120 Volt at the motor
  • JStar
    JStar Member Posts: 2,752
    Blower
    You should check the capacitor first, then ohm out the motor to check for continuity, open circuits, or grounding.
  • unclejohn
    unclejohn Member Posts: 1,833
    That motor
    Dosent have a run cap. Don't think those VS oil burners have been out that long it may still be under warranty. Call Carrier direct to find out, just give them ser.# at 1800carrier.probley just the controller is bad and not the motor. If its still under warrant have them replace both.
