Bad TXV ?
Jim Pompetti
Member Posts: 552
Ambient temp 85° F , box temp( low temp) holding about 30 ° F. High super heat. Suction presure 5 to 10 psi Head pressure around 225 psi . Evaporater frost (heavy) and evenly. Suggestion any one
refrig
What type of refrig, walk in box or under counter, what temp are you trying to maintain, are the derfost heaters oper. what type control , low press. control or liquid line sol. valve, door gasket condition. has someone been leaving door open.There was an error rendering this rich post.
We fer sure
Need every thing RJ asked and always start with a clear clean evap coil.0
- 15.8K Strictly Steam
