Fitting question
bill_105
Member Posts: 428
in Gas Heating
About 25 years ago I plumber friend of mine noticed a street ell in a gas piping system I did. I was told that you shouldn't ever use St. ells in a gas system because the male section of it has a reduced inside diameter than regular pipe.
Well 25 years later I just heard the same thing
BTW the inspector never said anything and only now did I hear this again.
Truth or fiction?
Truth or fiction?
Fittings
Here in NJ, the local gas utility uses A LOT of street fittings. I personally think the same as what you have heard. They do cause a restriction. And, they are more difficult to tighten with a wrench.0 -
Street ftgs
My old boss taught me to only use street el's and street 45's only when absolutely necessary for the same reason0 -
Close
If your piping it that close that a street fitting makes a difference. Bump it up a pipe size problem solved.There was an error rendering this rich post.
In my gas class
They told me it was because there is no ability in a street fitting to bend and stretch if the building collapses, same thinking with a close nipple that is all thread, if the building crashes down it will break spilling gas. I said if that was the case why are they made? Instructor just said just don't use them...? I like your reason better, but when I absolutely need it I use them.Tom
Montpelier Vt0 -
If the building falls
I don't think it much matters what fittings were used somethings going to break, especially with the crap pipe and fitting being sold lately.0 -
Prohibited practice
We in Canada specifically prohibit street elbows and tees. NFPA 54 does not.0 -
Q?
The measurements of the st. ell part is different than the gas pipe itself?
No T's in Canada? How?0 -
Street Tee
Street tees are are prohibited, as well as nesting bushings.0 -
Nesting Bushings
Henry, when you mention Nesting Bushings is that the same as saying face bushings? Thanks0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
