Radiant tubing and toilet wax seal
BigErl
Member Posts: 38
Hello everyone. I'm putting radiant in a bathroom floor using uponor quik trak panels and the 5/16" tubing. Is there a minimum distance I should keep between the tubing and toilet wax seal?
Rubber Seal
instead of wax no worries otherwise yes 8-12 "0 -
Thanks
Thanks Gordy0 -
I wouldn't worry.
Over the years I've had many people bring this up but I've left wax seals on my dash before in the summer and they don't get significantly deformed and that is way hotter than any radiant floor would get. I think the floor would be uncomfortable to walk on before it would be a danger to the wax seal.0 -
12" is what I do
keeps the tubes out near where your feet are anyways. I have seen wax rings that over time flowed out of place with the radiant too close. Then I used the foam rubber rings to replace them.Cost is what you spend , value is what you get.
cell # 413-841-6726
Wax free seal
I would use a wax free seal anyhow !0 -
Fernco
is the best waxless seal I have used. Deep boot and a tight fit even inside scaled cast iron pipe.Bob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
