Water source heat pump loop and hot water system
Chuck_17
Member Posts: 145
Water Source heat pump system – I have used a boiler for direct heat add (boiler used only for heat add). I have used a boiler for an indirect heat add (heat exchanger). I don’t think I had a system the hot water system was directly coupled to the heat pump loop (hot water used for entry unit heaters and heating ventilation air). I can’t think of any reason I can’t have the loops directly coupled as long as I have a heat trap. Am I not thinking of something?
(I am talking about a regular water source heat pump loop - not a ground source).
Wshp
If the cooling side of the system is an open tower, the constantly added fresh water can destroy the piping/boiler. I would keep the boiler on its own set of piping, whether a direct add or heat exchanger.0 -
Closed loop.
Closed circuit cooler. Closed system. I haven't tried to lay it out but the trick part is where to put the expansion tank.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
