Peerless burner plate insulation
Wallman
Wallman Member Posts: 1
The interior line on the plate seems detached, I manually pushed it back to the plate inner surface, but the plate, after a while, decolored and shows the burning sign, rust-like.
Could you please tell me as to what kind of material to use and how to reline the oil burner plate?
Thanks.
    Steamhead Member Posts: 18,205
    That's usually called the "front refractory"
    Any contractor should be able to get it from Peerless. What model boiler?
    Consulting
