Low water cutoff's
KBP&H_3
Member Posts: 67
Why don't low water cutoff's also include a pressure side that would also need boiler pressure to continue working.?
That would be
a pressure switch which is usually a separate device.
Personally, I don't like combination devices.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
