digital gauges
Paul_69
Member Posts: 251
can you buy one set of digital gauges that have a variety of refrigerants and use different hoses and flush manifold rather than buy another set of gauges.working on 410a and r22 only. thx
Why.
different hoses? Why flush the manifold? With some of the R22 replacements (HI,Med and/or LO temp) it is RECOMMENDED to add some mineral oil to the system to aid in oil return. Some say NEVER EVER cross contaminate the oils/freons.In the beginning of this oil/Freon thing when converting over to a "new" Freon/oil we were allowed to have 90-95% of POE and 5-10% mineral oil. Everything was good at those ratios. Gotta go back to work. I carry 8 kinds of Freon on board , so I guess I need lots more manifolds and evacuation manifolds also. Damn you!!!!!!!!!!!!!!!!!!!0 -
gauges
let me rephrase question. do you need seperate gauges for each refigerant0 -
Gauges
If you want to ,go for it! It is not mandatory0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
