WM Gold Plus 40 hw storage tank
Techman
Member Posts: 2,143
Are dielectric unions required on the boiler/domestic connections? What metal is the storage tank made out of?
It does not say they are required in the installation manual. My installing contractor did not use any, but he is not a contractor on whom I would rely.
The storage (inner) tank is stainless steel.
The outer tank, to which the boiler is connected is a more ordinary steel.
The piping coming out of the boiler is one-inch shiny steel (not stainless), and the contractor used 1 1/4 inch black colored (not the black pipe used for gas) steel pipe up to near the closely spaced Ts, and 1 1/4 inch copper for the rest of the near boiler piping and smaller sized copper for the rest of the secondary loops. Also 1-inch copper to the indirect. I have a Plus 40 tank too.It has survived 4 years use and is not leaking. That is not long enough to prove anything, of course, but that is all the data I have.
Here is a link to the installation manual; I cannot find it on the W-M site anymore.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CFgQFjAB&url=http%3A%2F%2Fwww.weil-mclain.com%2Fen%2Fmultimedia-library%2Fpdf%2Fweil-mclain-pdf%2Fproducts%2Fwater-heaters%2Findirect-fired-water-heater%2Findirec_fired_water_heater_plus_indirect_fired_water_heater_manual.pdf&ei=YmCjUdbAHJPK0gHwmoDIDg&usg=AFQjCNEbm4QCG_ZT49JpPnS1vogRO1AjTg&sig2=FQo-tvpLCI15nKytQ52zXg&bvm=bv.47008514,d.dmQ&cad=rja0 -
gold 40
Thanks JDB0
