Heating System requirements for New House
Shifty_ONeill
Shifty_ONeill Member Posts: 1
Heating system requirements for house to near passive house standard. Would the following be enough:
1. A stove with back boiler and rads for space heating
2. Mechanical Heat Recovery Ventilation unit
3. Solar Tubes and Electric immersion for DHW
What would you suggest?
  • SWEI
    SWEI Member Posts: 7,348
    Somebody has to do the math
    and figure out your design loads for both heating and cooling.  Then add up all the internal sources and factor in the 100% MUA requirements.  Almost certainly will want the ERV, may need a boost from a small heat pump or other sources on that air, depending...
  • Paul48
    Paul48 Member Posts: 4,469
    30 years ago
    I worked on a framing crew. We built a passive solar house that was a twin to one built in Nova Scotia. I never got a chance to see the mechancals of the house, but I can tell you that the construction is nothing like conventional. There's nothing difficult about it, but the engineering done beforehand has to be top-notch. Right from the site work, to positioning of the house and its orientation to the sun. There can't be any guesswork involved.
