By special request.
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,695
About those things a plumber must know? Let's see:
1. Water flows downhill
2. Cold's on the right; hot's on the left
3. Don't bite your fingernails.
I forget the rest. Feel free to jump in.
Retired and loving it.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    Water
    Water is not the only thing that rolls downhill! And payday is Friday!
  • Like Mark Eatherton Says
    I got pumps that will make water go uphill...
  • kevin_58
    kevin_58 Member Posts: 61
    plumbing quote
    righty tighty lefty loosey
  • Jack
    Jack Member Posts: 1,057
    Every time...
    I begin to think I'm a pretty smart guy I find myself in a place like this!
  • Condoman
    Condoman Member Posts: 97
    Always
    close the drain before taking the faucet apart!
  • rick in Alaska
    rick in Alaska Member Posts: 1,523
    shirts
    !. Keep your dang shirt tucked in!
    2. Look around and ask lots of questions. And get lots of training.
    3.  Always assume there is more of a problem than you think. Keeps you from fixing the "problem" and leaving, only to find the other one on the recall.
    4. See #1
  • psb75
    psb75 Member Posts: 1,118
    William of Ockham
    To rick of Alaska: I humbly beg to differ. One of the best "tools" I have ever acquired in my career is "Ockham's Razor," compliments of William of Ockham, a 14th cent. English philosopher/logician. Its a logically elegant principle of problem solving. Basically: start with the simplest fix, FIRST. E.g.: If your car stops running--check the gas gauge.
    I use the "Razor" almost every day.
  • icesailor
    icesailor Member Posts: 7,260
    #1 Rule:
    99,9999% of intermittent water leaks through a ceiling with a bathroom above it is from some form of water getting through the walls around a tub or shower or a leaking shower valve.
    Never take down a ceiling unless there is water steadily leaking through the ceiling.
  • rick in Alaska
    ockhams razor
    Whole heartily agree with that. What I was saying is just don't assume that when you find the basic problem that you are done. There might be a second issue that is not apparent until the first problem is fixed.
    Rick
    p.s. I also use the same problem solving sequence myself. Start with the most likely problem and then go from there. Gets me to where I need to be.
  • rick in Alaska
    payments
      Collect you payment as soon as you are done before the customer forgets how important it was to have you out there right now.
      Be polite.
      Clean up after yourself.
      Tuck your shirt in!!!
      Pass along the knowledge.
     Rick
