Opinions Wanted!!
BrianO
Member Posts: 12
in Oil Heating
I need to replace my boiler. I have a small split ranch in the Hudson Valley. I use fuel oil, and would like advice on which boiler might be my best choice for replacement. 75000BTU's would be more than enough, and I'm currently getting my domestic hot water through the coil. I'm open to other domestic hot water options (indirect tank, etc) What is the best Bang for my Buck For a New Boiler for My Home? Thanks to all for your advice!
Triple pass w/indirect
I prefer Buderus, Biasi or Viessmann and many others are fine too!To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Buderus G115WS/3
I was considering the Buderus G115WS/3 over a Burnham 3 section cast iron with coil. There's also a New Yorker that's similar to the Burnham for about $200 less, but I was thinking the Buderus may be the better option. It's a better efficiency I believe.0 -
Triple pass boilers
are the way to go. The Buderus and Baisi are both triple pass systems. I have a baisi B10-4 system in my home and it appears that it would be a very good match for your home if your btu rating is correct. The Basi B10-4 has an output of 84,000 btu/hr and is over 86% efficient. I make my hot water with a phase III indirect. This year I purchased 400 gallons for the year for a 1000 square foot, three bedroom ranch on Long Island. I keep the temp at 70 degrees in the winter.There was an error rendering this rich post.
Trio boiler
with Riello and an indirect. Available at F.W.Webbs. It is a rebadged Biasi.Cost is what you spend , value is what you get.
cell # 413-841-6726
Opinions Wanted!!
Just to let those of you who were kind enough to respond; I ended up with a Buderus G115WS/4 with indirect water storage tank as a fourth zone. It's running at 89% and I'm happy with the outcome. Thanks to all of you for your support.0 -
Could Have
saved a buck or two by getting the G115WS/3.
Did you get ODR?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
