Best paint for Baseray baseboard radiators
wad2
wad2 Member Posts: 1
Im in the middle of renovating 2 rooms. I have Baseray baseboard hot water radiators that I have already stripped all the old laytex paiant off of. We plan on painting these white.
What is the best primer and paint that can be used on these? I am hoping for something that won't turn yellow and won't smell when winter comes.
Thanks in advance!
  • SWEI
    SWEI Member Posts: 7,348
    Are you removing and reinstalling the radiators?
    If so, and the budget allows, have them powder coated.
  • J.R. Madden
    J.R. Madden Member Posts: 10
    Painting "Baseray"
    If the units are not being removed, clean them thoroughly. You can then apply a coat of "Rustoleum" or "Hammerite". either paint is available at most hardware stores. They can be purchased as a spray on or as brush on paint. They are designed for metal and produce a hard temperature resistant finish.
