Chemical for Cleaning Blocked Boiler heat exchangers?
SpeyFitter
SpeyFitter Member Posts: 422
Are there any products/chemicals you use that "assist" your manual efforts in the cleaning of blocked cast iron boiler heat exchangers?
  • Slimpickins
    Slimpickins Member Posts: 359
    My fave product
    Are you talking on the water or combustion side? The product I use to clean cast iron heat exchangers is a dolly to haul it outside and on to a truck to the scrap yard.  ; )
