Honeywell Mixing Valve
Member Posts: 4,639
I like the new Honeywell DirectConnect mixing valve kits. A real time saver!
clever design
are they competitively priced?0 -
And...
I looked and could not find any. Can you come up with some literature?0 -
clever idea
is that a low lead valve that California requires now a days?Bob "hot rod" Rohr
I can't believe
this is on here, I bought one yesterday for a customer, my tech installed it today, and I was waiting to hear back from him when he comes in at 5:30 to see how it worked out.... I couldn't believe my cost was under $85!!! If my guy says it was as easy as it looks Im going to stock them, these are a great idea....
I have a customer that has a radiant heating system running off of a condensing water heater and it has no mixing valve it is just set low {like 95*} but it runs out of heat pretty fast, so I was going to have my guys install a mixing valve this summer for him, this may work perfectly for that...0 -
Plus
they give you two extra ports - one for unmixed hot water (laundry, dishwasher, radiant to a heat exchanger, etc.) and another port for a recirculation loop return.
I saw this display on my suppliers counter on my way to the job where I needed one and even though I had two conventional mixing valves, I bought one for speed.
Here is the literature:
http://www.forwardthinking.honeywell.com/related_links/water/amx_300/install/62_3112.pdf8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
LF Version Available - AMX300TLF
There is a LF model available (AMX300TLF)0
