Repipe rad to loop?
Fizz
Fizz Member Posts: 555
Thinking of repiping 2nd floor Richardson rad to loop on separate run.  Rad doesn't heat unless valve to add-on 2nd rad(not a Richardson) attached to lat B is completely turned-off.  The system is 2 pipe.  Apparently supply pipe doesn't support attached edr.  Good idea?  Hope attached primitive drawing helps.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    I believe
    I believe your A pipe would have to be 2" for this to work.
    Retired and loving it.
  • Fizz
    So keep
    all attached as drawing, just change size of A pipe?  Thanks for quick reply!
  • DanHolohan
    Sorry
    Should have also mentioned that the risers to each radiator should be 1" instead of 3/4".
  • Fizz
    No problem
    Appreciate your input, very helpful.
    Thanks.
    Fizz
