BumbleBee question
Because Your Stuck
On water temp thinking if you keep it the same across the board your getting more heat. If the water temp across the board is the same you are not pulling out any btu/hr being moved through the distribution system.
All those btu/hr the boiler made went right back into it. You need to grasp that flow just carries btu/hr through the supply system it doesn't emit it.There was an error rendering this rich post.
So...
what's the next topic gonna be???0
- 50 Industry Classes
