BumbleBee question
13»
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Because Your Stuck
    On water temp thinking if you keep it the same across the board your getting more heat. If the water temp across the board is the same you are not pulling out any btu/hr being moved through the distribution system.
    All those btu/hr the boiler made went right back into it. You need to grasp that flow just carries btu/hr through the supply system it doesn't emit it.
  • Eastman
    Eastman Member Posts: 1,002
    So...
    what's the next topic gonna be???
