Radiators as Art
Dave in QCA
Member Posts: 1,806
Ok, most of us who tend to old steam systems come to appreciate the heating system and all of its components, especially the radiators, as objects of beauty and amazement.
Here is another take on the beauty of old steam radiators! I can't help but try to imagine the total weight of the collection..... of the salvage value....... and even the total EDR! WOW!
Click on link and scroll down.
<a href="http://www.spreadartculture.com/THE-HOT-WINDS-THAT-BLOW-FROM-THE-WEST">http://www.spreadartculture.com/THE-HOT-WINDS-THAT-BLOW-FROM-THE-WEST</a>
Dave in Quad Cities, America
http://grandviewdavenport.com
So,
what do you suppose the output would be?Retired and loving it.0 -
whoa!
Dan, you really do watch this thing!
Well, a very rough estimate with the assumption that the cube of radiator is solid and with no hollow space in the middle. And, assuming that the stacked manner would not reduce the effective EDR, which it would. My very rough visual measurement is about 4000 EDR or 960,000 BTU output.
What's your guess Dan?Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Well, it would be cozy!
The guy that was trying to heat the room for the printed circuit boards could use this. ;-)
Thanks for sharing, Dave.Retired and loving it.0
