UNUSUAL STEAM VALVES?
BRIANJ
Member Posts: 118
HAS ANYBODY EVER SEEN ANYTHING LIKE THIS.
<a href="http://www.ebay.com/itm/ANTIQUE-RADIATOR-VALVES-3-4-AND-1-2-STEAM-RELEASE-LOT-OF-5-ALL-NEW-/290895523847?pt=LH_DefaultDomain_0&hash=item43bab97007#ht_656wt_1130">http://www.ebay.com/itm/ANTIQUE-RADIATOR-VALVES-3-4-AND-1-2-STEAM-RELEASE-LOT-OF-5-ALL-NEW-/290895523847?pt=LH_DefaultDomain_0&hash=item43bab97007#ht_656wt_1130</a>
BRIAN
BRIAN
Steam
Those are test cocks. They let you manually check the water level in a gauge glass or boiler.0 -
Also known as
These are also known as Try cocks. They are used if a gauge glass is broken or plugged. The three test points will tell you where the water line is. Bottom cock should spray water, middle cock should spray a mix or mostly water. Top cock should emit steam only.
Here is a link with some pictures that explain how it works. http://constructionmanuals.tpub.com/14279/css/14279_56.htmDave in Quad Cities, America
http://grandviewdavenport.com0 -
Thanks for the information
I thought these valves were rather unusual. Not something you see in a standard home owners boiler. And it's a good day because I learned something new.
Thanks again, Brian0
