Steam Boiler Water Treatment
Any good resources out there for steam boiler water treatment,PH levels,ETC. I seem to remember Dan H. writing an article about this topic in the past?Thanks in advance for any help!
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Water conditions
    What conditions are you trying to correct with the present water supply?
    Most us here will only put pure water in a steam boiler, unless a chemical analysis shows the presence of dangerous chlorides, or the PH being out of whack.
    A properly running system should only need a few gallons of water made up per year. --NBC
