Red Line 0-30 PSI Gauge
I am sure that there are probably a million reasons not to use or install one my boiler. But I just realized walking through the the shop at work that a 0-30 psi acetylene gauge would look really cool on steam boiler. Something like:
<a href="http://www.ebay.com/itm/WIKA-8610860-2-5-0-30-psi-PRESSURE-GAUGE-COMPRESSED-GAS-REGULATORS-111-11-/220934215192">http://www.ebay.com/itm/WIKA-8610860-2-5-0-30-psi-PRESSURE-GAUGE-COMPRESSED-GAS-REGULATORS-111-11-/220934215192</a>
Especially with the scary red scale at over 15 psi. I doubt it would ever move or be useful, as my system only ever sees maximum pressure of  24 oz on a long run. But the cool factor would be high.....
Cheers
Richard.
  • Boiler Talk
    Boiler Talk Member Posts: 144
    What difference, at this point, does it make?
    Well, I suppose there is no law that states you have to have a graduated gauge above 15 lbs.  I guess above 15 lbs should never happen with a properly functioning release valve.  But that is not the case according to accounts here.  Why not have a gauge that records the highest reading that can be reset?  Who watches the gauge 24 hours anyway?
