rheem warm air furnace
Paul S_3
Member Posts: 1,294
in Gas Heating
I have another problem with burners not lighting fully across...brand new them two stage furnace...only one burner lights...the one closest to the spark igniter...they light full across when I blow the gas around when its trying to light....I checked incoming gas pressure I'm getting 6.8" wc....on the outlet I'm getting .40"wc reading on both high and low fire...cannot adjust both high and low regulator on gas valve....I screw the set screw all the way down and up on both high and low regulator with no change in pressure and visible firing rate....faulty gas valve???
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
model and serial
Rheem......model # rgpe-10ebrmr.....serial#gz5d301f391204792ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Gas
Were you getting 6.8 in when the valve was open, or only static?0 -
6.8"wc
With valve openASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Rheem
Sounds like the valve. I would try to send 24v right to it first. Could also be a low amp draw on the valve circuit, which might lead to a faulty control board.0 -
Did you
call Rheem tech support? Sounds like a gas valve, is this a natural draft installation?0 -
I seem to recall
hearing of manufacturing oil in the burners block the crossover. Try washing out the burners.0 -
Is this the set screw
Adjustment that has a 2mm set screw inside a 3mm set screw? If it is you need to replace the valve and If you ever find the guy that dreamed that up, kick him in the butt.0
- 123 Chimneys & Flues
