Question on sizing flat plate heat exchangers
earl burnermann
Member Posts: 125
So I am designing a system for my home as a project for the system design class I am attending. My home is heated by a oil fired hot water boiler and baseboard. I could just design the ac side for this class but I’m thinking of also including a hot water coil which would eliminate the baseboard. I completed the Manual J for my home and it states that my heat loss is 65,400 Btu/hr.
My plan is to use a flat plate heat exchanger, the type of heat exchanger that the system 2000 uses to make domestic hot water using a plain electric water storage tank, to supply a 50/50 premix of glycol to the coil. My problem is that I am having trouble finding the Btu ratings of these devices. Also, the specific heat of glycol is .85. So I figure the flat coil would have to be rated at 75,000 btu/hr right?
Thanks,
Brian
Thanks,
Brian
Thanks
For the info!There was an error rendering this rich post.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
