Crab steamer
LWH
LWH Member Posts: 1
Any tips on installing a steam boiler to steam crabs...hot water for make up from water heater or coil, piping diagrams etc
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Constant loss steamer
    There are a few postings here on that subject, so do a search.
    The problem to be overcome is the constant addition of fresh waste to the boiler which can introduce too much oxygen into the boiler hastening it's demise.--NBC
    Steamhead Member Posts: 18,184
    Here's one we did
    in the back of a truck, no less............
    http://www.heatinghelp.com/forum-thread/138701/In-the-Land-of-Pleasant-Living
    Consulting
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,682
    Feed water
    Feed it through a small water heater, set at the highest temperature, and use a microbubble reabsorber in the feed line. That will take care of the air and the heater will give the sediment a place to settle, other than inside the boiler. Adds years to the boiler's life.
    Retired and loving it.
  • vaporvac
    vaporvac Member Posts: 1,520
    WaterHeater, microbubble reabsorber?
    If this works to prevent the introduction of co2 into the system, why isn't it used with residential steam for make-up water?
  • JStar
    JStar Member Posts: 2,752
    Steam
    Why, indeed.
    The reason is...no reason.
    The REAL reason is that a residential boiler should not be using a lot of fresh water. And if water is added for maintenance, it should be boiled immediately. Whatever sediment accumulates over the years can be cleaned out.
    In this crab steamer, there is so much fresh water being used daily, that you there is no way to maintain it often enough to prevent a problem.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    edited April 2013
    You can use hot water for make-up water
    But don't run it through an automatic water feeder.
    (Actually, consult your local code. It might not allow this.)
