What do you use to flash external terminations?
heatpro02920
heatpro02920 Member Posts: 991
I have been using the plastic trim rings but they don't go down to 3/4", what are you guys useing if anything to trim your outdoor pipe terminations? I need some for 2" ovc, 3" pvc and 3/4" pvc... escutcheons that wont rust and are not chrome, I need rubber, or plastic ... thanks
