SEER RATING
Paul S_3
Member Posts: 1,294
i have seen people increase size of evap coil 1/2 ton for increased effeciency for example 3ton condensor with a 3 1/2 coil....but i recently been seeing new installs due to the hurricane with 3 ton condensors with 5 ton coils is that right????the answer ive been getting is" thats the only way they can get the seer rating high"???can anyone tell me why you would increase evap coil and the proper way to do it??
PAUL S
PAUL S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
SEER
http://www.ahridirectory.org/ahridirectory/pages/homeM.aspx
This is the only way to do it. Use the AHRI directory.
A bigger coil can absorb more BTUH. It's not just a blind science, though. Sometimes a 3 ton condenser will produce the same SEER rating with a 3.5 ton coil as it does with a 5 ton coil.0
- 123 Chimneys & Flues
