Steam Radiator problem
RFlynn
Member Posts: 2
I have been trying to figure out why a steam radiator at the end of the line is not working even when the riser is getting hot on the radiator itself. I have taken out the vent and it still does not heat up. It seems to be taking all the heat to the radiator about 5 feet away but does not get to the one at the end of the line.
Should I try and put a vent at the end of the line so the steam to get there quicker?
Not sure what the problem is, pelase help.
Thanks
Rob
Thanks
Rob
Has anything changed?
is this a new boiler? Is the boiler oil or gas? I have come across many underfired systems this year.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
