Floating Action
Nick Ciasullo
Member Posts: 44
I have a control that is designed to control a floating action valve. The end user wants to use a valve that takes a 0-10v signal. Is anyone aware of a device that I can purchase that will convert one to the other?
Floating to analog interface
http://workaci.com/products/aud-flotating-point-analog-output
This is a link to the technical instructions for the part # AUD. It is an interface manufactured by ACI. It should control as requested. Note there are 4 models. Suggest you have available your exact control and valve actuator, give Mike B. (or anyone available) a call at 888-967-5224 to see which version suits your application. Ask him if they will factory pre-calibrate for a small setup fee prior to shipping.0
- 167 Indoor-Air Quality
