Standby losses out the chimney
New2heating
Member Posts: 1
in Oil Heating
Does anyone know of how I would figure out how many BTU's are going up the chimney when my boiler is on standby? I have a Weil McClain set at 150 to 170 degrees. Thanks!
I normally
call a chimney vented appliance with no outside air intake 5-10% energy loss, that is just what I notice going from natural draft to direct sidewall vent...0 -
Math
Figure out the amount of energy stored at 170 and the amount stored at 150(don't forget the differential). The difference is standby loss assuming no intervening demand. Water has a specific gravity of 1,cast iron is .090 -
Here's a file
We have a Peerless 3 section with a tankless coil at our house. I turned the boiler off and took temperature readings a couple of years ago. I made a spreadsheet converting gallons to BTU's, etc.
The direct and indirect numbers assume 6 to 8 degrees per hour and 1/2 to 1 degree per hour idle loss respectively. It's been a while.
Have fun.0
- 167 Indoor-Air Quality
