Gas light parts
zepfan
zepfan Member Posts: 458
Does anyone know where to get parts for gas lights that you would have installed at a house? I have a customer that has one that is about thirty years old, that there is no manufacturer or make on. I am looking to replace the control knob that is broken, if the part or rebuild kit is available.thanks to all.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    Gas lights
    Can you post a picture of the light, and maybe the valve in question?--NBC
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,100
    Humphrey...
    ... is the last maker of gas lights I know of.  I'm pretty sure they are still in business.
    Yours,  Larry
  • Matthew Grallert
    Matthew Grallert Member Posts: 109
    lehmans nonelectric
    try Lehmans nonelectric I could be wrong on the spelling.
    good luck
    M
  • tim smith
    tim smith Member Posts: 2,935
    Re: gas lights etc
    Solara lighting still sells some real fancy gas lights. Quite nice.  I think I still have some mantles  for the old gas lights we use to work on here in Seattle.  Basically the same as the old fibrous ones in coleman white gas lights.  Pretty simple
  • zepfan
    found the parts
    i was able to find the parts from a company called modern home products,and then bought them locally.they worked perfect.thanks to all
