winterize
almartia
Member Posts: 1
in Oil Heating
If I decide to leave my oil furnace on, set at 43 degrees, to heat the house while it is vacant during the NH winter, I've been told that I should also shut down the power to the water well and pump and drain the pipes. How does this affect the hot water baseboard heating?
Is the baseboard heating a closed water system..... Will it work if the rest of the house has no water because it has been turned off?
I don't want to "winterize" the house and let it sit cold for the entire season...could damage wood floors, walls, & foundation.
it shouldn't
as long as the system is tight. Try shutting off the fill valve for a few days and see if your pressure drops.0 -
Other ideas.....
To me, 43 is cutting it close. Doesnt give you much leeway if the system has a problem. If it were me, I would make sure there is some freeze protection to warn you if the heater shuts off--alarm contacts on the primary control or thermostat. Also, you should have a low water cut-off also...just in case.There was an error rendering this rich post.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
