What should the proper fpm velocity be for a furnace in a
ElderGreen
Member Posts: 25
1000 sq foot ranch house? Quite open inside without walls every 5 feet. Only the single bedroom and bathroom are partitioned off. Blower is rated for 1000cfm. Just trying to decide which ducting size for the supply. Then I'll just increase it a bit for the return. Any help is greatly appreciated folks!
thinking 700
does that sound adequate?0 -
At 700fpm
Your at less then .05 SP you should be able to go up to 900 fpm with no real noise.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
