how much BTU does a person give off
charliechicago
Member Posts: 178
Hello to all
How much cooling BTU (both sensible and latent) do you need the heat given off by a person?
Thanks, Michael.
Thanks, Michael.
thanks
thanks swei0 -
For Down-and-Dirty Calculations
For back-of-the-napkin calculations and for casual conversation, we often equate the heat generated by a person to be the equivalent of a 100-watt light bulb.There was an error rendering this rich post.
Thanks
Dr. Silberstein. I am actually looking for an accurate number. I need to do a heat load calculation for a house of worship and need to be precise.
Thanks agian, Michael.0 -
Excellent!
Then the chart provided by SWEI will work perfectly!
Enjoy!There was an error rendering this rich post.
Ok
Thanks again, Michael0 -
Ok
